Who sells a T.V. bracket for vortec intake?
Old Aug 31, 2001 | 04:25 PM
Jay 727's Avatar
I am changing to vortec heads and an Edelbrock vortec intake, my '76 350 has the tv cable bracket that bolts to the rear intake bolts which obviously won't work with the new intake. It will also have a holley carb with the throttle arm geometry correction bracket. Who sells the bracket to mount to the intake?
Thanks in advance.
Old Sep 1, 2001 | 11:31 AM
SC88's Avatar
Car: 1988 Camaro SC
Engine: 355 Chevy
Transmission: 700
Hey Jay. For my car I used a Mr. Gasket throttle and tv bracket for my vortec set up. I am using the Air Gap and I have no where to put a bracket. The Mr. Gasket bracket mounts to the bolt on the carburator. I used a holley 650 dp and a edelbrock 600 nd it worked on both. I'll try to get the part #'s for it.
1988 Camaro Sport Coupe: Orignally: 305 TBI 700r4
Now: 1974 350CI, 2bolt,.030 over, Badger Flat Head Pistons w/ valve relief, Melling high performance street cam, GM Cast Vortec Heads, Edelbrock RPM Air Gap Intake, Edelbrock 600cfm w/ electric choke, GM HEI w/ vacuum advance, Weiand Low Profile Air Cleaner, Mallory 5 port Fuel Pressure Regulator, Mr. Gasket Throttle Cable Bracket, Corvette Shift Servo, 16" IROC Wheels, Every thing else is STOCK
Soon: 3.73 or 3.42, Gears, Hoosier Q/T
Old Sep 1, 2001 | 11:32 AM
SC88's Avatar
Car: 1988 Camaro SC
Engine: 355 Chevy
Transmission: 700
Also you might have to get a longer cable.....
Old Sep 6, 2001 | 10:39 PM
Crosley4's Avatar
here I thought the heads eliminated the middle intake bolts, not the end bolts?
Old Sep 7, 2001 | 01:55 AM
85 Berl's Avatar
The heads have 2 bolts at each corner, but they point straight up, instead of at an angle. I have the Vortecs, and Edelbrock Performer intake. I bought a kit for the TV cable from Bowtie Overdrives. I saw them in a recent issue of Car Craft (I think). I'm in the process of installing it now, and it should do the trick. The kit comes with a plate that goes under the carb, and has the bracket on there.
Sorry, it's hard to explain. There website is www.700r4.com. Go to the sitemap, and look for "TV made easy". they have some pics there.
Hope that helps.
Old Sep 11, 2001 | 07:43 PM
Changa2's Avatar
You might look into the Holley bracket that mounts to the rear carb stud. P/N 20-95 for about $17.00.
I have a Holley sitting on an Edel Performer RPM manifold. Works fine.
I replaced my TV cable mainly because the tip was broken. It was an adjustable type of cable that (I think) I would have needed anyway.
Sorry for the delay, as I was interrupted by some unimaginable news alert.
Old Sep 11, 2001 | 10:38 PM
JPrevost's Avatar
Car: 91 Red Sled
Or if you have a table vice and a grinder you can modify your stock piece to work with the vortec intake. I have a picture on my website of a modified bracket. It still bots to the rear intake bolt and slides like a 'C' onto the mounting bolt for the coil.
It took me maybe 10-15 minutes. If you're interested just e-mail me, I'll send you the specific link. Right now I'm tired from this busy and tragic day.
, Jon (350 TBI!)
91 Red My website
Frozer!!!
Jan 19, 2024 04:55 PM
92firebirdchris
Exterior Parts for Sale
Aug 14, 2015 11:56 AM
Firechicken86
Aug 12, 2015 10:07 PM
mcgarnicle
Aug 12, 2015 04:58 PM
SiCkRs
Aug 8, 2015 08:12 AM
