SPLINE ?
SPLINE ?
I want to get a posi unit for my 92 rs.Jegs is saying I have a 30 spline axle but all the articles Ive read either say 26 or 28 spline axles.The question is which axle do I have?Thanks for the help!
Car: 4
Engine: 6
Transmission: 5
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
You need a posi for a 7 1/2"/7 5/8" 10 bolt. There are actually 3 different sizes of GM 10 bolts. The one you have, an older but not popular 8.2" and the strongest 10 bolt is a 8.5" Those larger 10 bolts could use 30 spline axles. The 7 1/2" diff is just too small to fit a 30 spline axle into the carrier. (not that there are any 30 spline carriers for it anyway).
90 and up f-bodies all have 28 spline axles. 90-92 f-body axles will fit in all 82-92 housings that use a 28 spline carrier. 93 and up axles are 2" longer.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.89
Best MPH on a time slip: 121.52 altitude corrected to 125.89
Altitude corrected rear wheel HP: 497.9
Best 60 foot: 1.546
Racing at 3500 feet elevation with a typical race day over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.546
codeysabatini
Nov 10, 2015 04:07 PM
Prodigious
Sep 18, 2015 05:23 AM
