Need some help!!!!
Car: 1984 Camaro Z/28
Engine: 425hp 388 Stroker
Transmission: TCI TH400
Axle/Gears: Ford 9" 4:10s
Need some help!!!!
Is there some kind of bracket that connects the torque arm to the tranny or, does the torque arm bolt straight to the tranny?? because im seeming to have trouble getting mine hooked up.
Re: Need some help!!!!
There is a rubber/ poly bushing (bracket) that goes onto the tail housing and you bolt the torque arm into that. you can get them from jegs/summit. I beleive the stock ones are riveted on.
