Automatic to manual
Old Sep 22, 2001 | 08:40 AM
jared311's Avatar
Automatic to manual
Hey, I justread the article on swapping an automatic tranny to a manual. It all looked fairly possible, but I didn't even see the computer chip mentioned. If it's geared for an automatic, wouldn't I have to buy a new chip? And if so, would it be cheaper to just buy a different car that already has manual?
Old Sep 23, 2001 | 09:08 AM
ede's Avatar
ede
you shouldn't need to change the prom or ecm. the only problem area might be if you have an eletric speedo. did you read the piece jester wrote? he got the trans from me out of an 88 and it went into a 91 (i think) with no major problems.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Sep 23, 2001 | 12:42 PM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
The only problem I had with mine is when you first start it you got to let it idle down before you go anyware or else your car will keep at 1500rpm when your driving, like if your slowing down for a stop light it will stay at 1500rps and the same if you have your cluch in untell you stop and let it idle down . So you start it wait 20-25 sec to let it idle down and the car will drive like a normal standard car the rest of the day.
Now why it does this I don't know but maybe one of the chip guys can explain this problemm that I have?
89 T-Top GTA 350 5-speed (soon to be 6-speed)
(Jet hot coated)1 3/4 SLP headers,flowmaster force 2,no cat's,SLP cold air,MSD 6al,march pulleys,ported plenum,air foil,B&M ripper shifter,180 stat,alston SFC,spohn LCA relocation brackets,ES LCA and Panhard bushings,free mods.
0-60 5.2s
Track Time
60' 2.049
E.T. 14.14@96.7MPH (2270 FT)
13.76@99.4MPH corrected
Old Sep 23, 2001 | 03:05 PM
86IROC305's Avatar
I just swaped my auto to 5spd last weekend and I'm having the same problem ! I was trying to find out what was causing it and was considering swapping chips, but if I'll try letting it idle all the way down first. I haven't had much time to drive it, had to pull it a day after because of no 5th gear and still haven't got the tranny back from the shop yet Hopefully it will be done tommorow....
86 TPI 305 Iroc-Z
5spd
9 Bolt Rear Disc Swap w/ 3.45's
Accel HEI SuperCoil
Flowmaster
K&N Filters
Comp Cams 260H-12
212/212 444/444 @112lsa
[This message has been edited by 86IROC305 (edited September 23, 2001).]
Old Sep 23, 2001 | 10:57 PM
86Chicken's Avatar
Mine did that too. I replaced the auto chip with a GM one for a manual and the problem disappeared.
Dale
1986 FireBird
2.8L MPFI
1/2 CAI
Gutted Cat, No muffler
Was 700-R4 --> Now T5
Great cars aren't bought, they are built
Falcon50
Aug 22, 2020 03:26 PM
Lbibb
May 5, 2016 12:00 AM
Fireslash
Apr 11, 2016 06:43 PM
jrdturbo
Mar 31, 2016 02:58 PM
loud91rs
Oct 5, 2015 10:05 PM
