T-5 Hydraulic Assembly
Old Sep 22, 2001 | 04:51 PM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
I am swapping a T-5 in place of my 700R4 and I need a new clutch master/slave assembly.
I had heard that the 4th gen T-5 clutch assembly is better to buy because it doesn't have a restrictor that is a problem with the 3rd gen version.
Anyone have some knowledge on this?
Thanks!
Old Sep 23, 2001 | 01:26 AM
Project86Iroc's Avatar
From what I understand, The 4th gen have the same restriction. It is easily removed though. I have a CHP with the whole how to somwhere around here. My problem is finding just the hydraulic line (somebody cut mine)
Mike
I would love to be there when those Muslim Bastards hit the Pearly Gates and realize they were wrong...
Old Sep 23, 2001 | 09:41 AM
Engine: LS3
Transmission: 6L80E
What does this restriction do?
I have been thinking about just getting an aftermarket one from Wagner, however, the aftermarket one has the master and slave as seperate part @'s. I don't know if the restriction is present there too...
So, what does this restriction do?
Old Sep 24, 2001 | 12:04 PM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
The only master/slave combo I've heard of that has a restriction is the LS1 version. Where did you hear about the LT1 version having a restriction?
Old Sep 24, 2001 | 04:55 PM
87RS402's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Project86Iroc:
</font>
I had to replace a section on mine and put in a compression fitting to repair the damaged section.
Old Sep 24, 2001 | 04:59 PM
Engine: LS3
Transmission: 6L80E
The only restriction that I have heard of is on the 5 speed models...not the six speed.
Not sure about how or how these restrictors were used or in what models...just what I heard of.
-Adam
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
skinny z
Oct 5, 2015 06:23 PM
gord327
Oct 3, 2015 01:25 PM
mfp189
Sep 27, 2015 09:25 AM
Dragonsys
Sep 25, 2015 03:51 PM
