Carrier Question
Old Sep 26, 2001 | 07:23 AM
CamaroRS's Avatar
Carrier Question
In a ten bolt rearend, what is the difference between a 2 series carrier and a 3 series carrier?
Old Sep 26, 2001 | 09:18 AM
82camaro's Avatar
Car: 82 camaro SC
2 series is thinner(3.08 and lower numeric gear ratio) and 3 series is thicker(3.23 and higher numeric ratio). It's done because as the gear ratio gets smaller the pinion gear gets bigger and the ring gear needs to be moved over to align correctly.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
hectre13
Dec 11, 2023 08:14 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
hectre13
Aug 26, 2015 08:17 AM
redmaroz
Aug 16, 2015 11:40 PM
knight72
Aug 10, 2015 09:32 PM
