TH350 or 700R4
Old Sep 28, 2001 | 03:52 AM
1987Formula350's Avatar
TH350 or 700R4
I have a 87 Formula350 that will soon be sporting a new 355 with all forged components and a weiend 6-71 supercharger.And also a 125hp shot of nitrous oxide. The problem is that I don't know what do do about a transmission. I doubt my 700R4 can handle this, and I don't really want a TH350 cause I need to drive on the highway. The car has been stripped of all its electronics including the computer so I can't have an electronic transmission. Is there anyone that makes a 700R4 that can take the estimated 700 horsepower that this engine will produce. Or am I doomed to drive a three speed.
Thanks,
Old Sep 28, 2001 | 08:39 AM
82camaro's Avatar
Car: 82 camaro SC
Is it a race car or a street car? What gears do you have? With that combination I would lean towards a th350 because it's cheap and strong and forget about the overdrive. With a more mild engine the 700r4. With 700 hp, your mileage is going to suck with or without overdrive.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
