Lost OD, Attn Pro-Built and others!
Old Oct 4, 2001 | 02:18 AM
Omar's Avatar
From a dead stop, my OD acts like it's in neutral. I have to be going at least 40mph in Drive (3rd) before I can manually shift it into 4th. Then it kicks in. Any suggestions?
1989 IROC-Z 5.7L
NOS 5151 150HP kit
ProBuilt 700R4, PI Vigilante 2800 stall lockup
Baer Brakes 12" Sport System
Old Oct 4, 2001 | 04:12 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
I'll take a shot at it, I may be wrong but...
I think your sprag is shot. When you are in 3rd it works fine because the direct clutches are 'helping' the sprag lock, but when you are in OD, the forward clutches are not engaged and leaves all the work to the sprag.
Driving it like this puts alot of stress on those clutches and they won't last too long.
Old Oct 4, 2001 | 05:26 AM
Pro Built Automatics's Avatar
Sounds like you broke the overrun clutch hub, call me tomorrow after 11am PST (800 7763288) and I will see what needs to be done to solve /fix this.
Old Oct 4, 2001 | 05:51 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Ditto on the sprag/hub.
I have seen several failed sprags, but the hub is just as likely.
FREE CARFAX Record Check
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
[This message has been edited by GMTech (edited October 04, 2001).]
ZZ3Astro
Aug 13, 2019 12:57 AM
djmarch
May 8, 2016 11:32 AM
86White_T/A305
Mar 6, 2016 01:48 PM
Jynx88
Oct 4, 2015 08:19 PM
3.8TransAM
Sep 27, 2015 08:37 PM
