couple rear end questions
Old Jun 22, 2009 | 11:32 AM
camaro1185's Avatar
Car: 1988 Iroc
Engine: 5.7L
Transmission: '96 T56, Hurst Shifter, Mech VSS
Axle/Gears: 3.45 9 Bolt
1. How can i figure out if i have a 9 or 10 bolt? RPO codes maybe?
2. My diff is leaking, what type of sealant should i use? (silicone?)
3. what gear oil is the best?
Old Jun 22, 2009 | 11:53 AM
big gear head's Avatar
Re: couple rear end questions
9 bolt = 9 bolts in the cover. 10 bolt = 10 bolts in the cover. Any 80W90 or 75W90 gear oil will be fine, but I use Amsoil. Where is the leak?
Old Jun 22, 2009 | 12:03 PM
camaro1185's Avatar
Car: 1988 Iroc
Engine: 5.7L
Thanks thats what i figured, but i havent been under the car to check. From what i can see it looks like it is comming from the lowest part of the "meatball"
As far as sealant, what do you use?
Old Jun 22, 2009 | 12:47 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I use a gasket. Many use RTV.
JamesC
Old Jun 22, 2009 | 01:09 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I haven't used any sort of diff cover gasket on any diff I've worked on for years. RTV works fine. I usually use Permatex Red (it's orange).
80W90 or any synthetic gear oil will work fine. If you have a posi, a posi additive should be used. GM makes the best posi additive and it stinks worse than a pig farm.
My race car uses 75W90 Lucas oil in the diff that one of my sponsors provides.
Old Jun 22, 2009 | 01:40 PM
Check the pinion seal. Many times the pinion seal will leak and the oil runs back to the rear of the housing and it just looks like the gasket is leaking.
Old Jun 22, 2009 | 02:33 PM
camaro1185's Avatar
Car: 1988 Iroc
Engine: 5.7L
Good point. I saw some leakage and just figured it was the diff leaking. thanks.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
novaderrik
Aug 10, 2015 12:44 PM
