Shifting trouble
Old Jun 23, 2009 | 06:01 PM
Nikadeamus's Avatar
Shifting trouble
I've got a 1992 Camaro RS that I'm having some trouble with. I'm not great with cars, as this is my first one. It is parked in my driveway and yesterday when I tried to leave it wouldn't go into gear. The shifter is very loose and moves back in forth showing it is going to other gears, yet it doesn't. When I put it in reverse the tail lights show it is in fact in reverse, but it isn't engaging with the transmission. Anyone have any ideas as to what could be wrong? If so could you explain how to fix it? Diagrams and pictures would help as I'm not to familiar with working on cars.
Thanks...
Oh and it isn't the stock shifter. The person that owned it before me but a BME slap shifter on it.
Old Jun 27, 2009 | 09:35 AM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Re: Shifting trouble
Sounds like the shift cable broke. Look under the car on the left side of the transmission and see if the cable has come detached from the manual lever on the side of the case. If that connection is good you will have to take apart the shifter inside the car and see if thecable broke from that end.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
mrbird
Oct 20, 2015 03:43 AM
racereese
Oct 3, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Lmancha96
Sep 25, 2015 08:11 PM
