FYI - GM PNs for T56 plugs
Subscribe
Oct 9, 2001 | 08:50 AM
This question keeps popping up, so I thought I'd post it in one message.
12101899: VSS sender
12101857: Reverse Lockout solenoid
12101857: Skip Shift solenoid
The reverse light switch is a standard two-socket weatherpack; if you are swapping from a five speed the stock plug will work. If you are swapping from an automatic, you can pick one up at any Pep Boys among other places.
"Beware he who would deny you access to information, for in his heart, he dreams himself your master"
'84 Black Camaro Sport Coupe ZZ4 350 M6 -- '84 Olds Cutlass Supreme 231 A3
'91 Medium Blue Metallic Z28 400 A4 -- '99 Navy Blue Metallic Firehawk #120 346 M6
Reply 0
Oct 9, 2001 | 09:37 AM
is the VSS plug all that I need to hook up an autometer electric speedo? I have an 89 IROC that I put a T56 in a month ago, and I am getting phantom gauges, so I was just wondering if I need a sending unit or just the plug and speedo.
Tim
Reply 0
Oct 9, 2001 | 10:17 AM
The sending unit is in the tranny, so once you get the plug you will have a VSS signal. Whether it will be compatible with your aftermarket gauge I don't know.
I'm using a stock 91 speedometer and it requires a converter box. I'm going to use the SGI-5 from Dakota Digital.
Reply 0
Oct 9, 2001 | 12:55 PM
The dakota digital box works good, once you figure it out. If you have any questions, let me know, just got mine hooked up over the weekend.
Reply 0
Oct 10, 2001 | 09:43 AM
I think I'll worry about getting my clutch to work before I mess with the dakota digital box.
Reply 0
Subscribe
