Rear Swap
Old Jun 27, 2009 | 11:25 AM
SierraSR25's Avatar
Car: 1988 Firebird
Engine: 355
Axle/Gears: Moser axles, 342 gears
Rear Swap
I have a full built rear from a 70 camaro that i am trying to put in my 88 camaro. Is there any way of doing this before i start ripping things apart?
Old Jun 27, 2009 | 12:36 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Rear Swap
Nope.
Second gen uses leaf springs. Third gen uses coil spring and a torque arm suspension. There's no way to attach the torque arm onto the second gen diff.
Old Jun 27, 2009 | 04:35 PM
big gear head's Avatar
Re: Rear Swap
It can be done, but it's A LOT OF WORK. Is the '70 rear end a 10 bolt or 12 bolt? If it's a 12 bolt then sell it and put that money toward a Moser 12 bolt. If it's a 10 bolt then it will be the 8.2, which isn't much better than the 7.5 that you have now.
customblackbird
Aug 15, 2021 10:16 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
E Rod
Aug 28, 2015 05:17 AM
jharrison5
Aug 19, 2015 05:53 PM
mizz0313
Aug 12, 2015 06:45 AM
