700r4 rebuilt but bad judder
Old Jul 12, 2009 | 02:24 PM
IROCmatt's Avatar
Car: IROC Z28
Engine: 5 litre 305
ive had my tranny re built, its fine but 1st gear judders reall bad almost like its not gonna move, once its in second its perfect, if i put the car in overdrive it does not have the problem but does drive as well as it should.
Could it be the band slipping? as the car does not move untill you ease off the power
Old Jul 15, 2009 | 01:43 AM
ed o's Avatar
Car: 64chevelle/smokey trans am
Engine: 350 p600 pro charger/350
Transmission: 350/700r4
Axle/Gears: 3.36
Re: 700r4 rebuilt but bad judder
the rebuilder must have messed up somewhere. Maybe forgot to install the correct number of clutches in the forward clutch pack or in the low reverse clutch pack. or installed the wrong thickness ones, or possibly tore the rubber or sealing rings during fixing it. Sounds like it will have to come back out. DOH
Old Jul 15, 2009 | 06:42 AM
IROCmatt's Avatar
Car: IROC Z28
Engine: 5 litre 305
i hope it does not need to come out, the guy that built it knows his stuff, its alright if u pull away gently and fine in over drive which i cant understand, surely it should judder in overdrive as well
Reddeath210
Oct 6, 2015 08:20 AM
backtothe80s
Sep 5, 2015 12:39 AM
someone972
Aug 30, 2015 12:52 AM
g.l.mos
Aug 22, 2015 12:02 AM
86IROC112
Aug 21, 2015 07:20 PM
