83 700r4 to a 87 700r4
Old Oct 26, 2001 | 03:31 PM
speedfreaker's Avatar
i have an 83 transam and want to switch it out to another "mine died" so i found an 87 700r4 for cheep will it bolt right up will i have to change anything ???
CHRIS
1983 firebird transam
edelbrock performer rpm intake 360*k&n intake 160 theroostat gitting trans raced up and lots and lots of plans 4 the future
Old Oct 26, 2001 | 06:53 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
Yes it will..
The externals are the same but the internals from a 87 are a lot better than the ones in 83
Kat
[This message has been edited by Kat (edited October 26, 2001).]
Old Oct 27, 2001 | 09:10 AM
transfixleo's Avatar
You may want to check to see what Servo your original had and what is in your new one. The last numbers cast into the piston should be 553, DON'T use 554 and if you had 093, use that. Take a look at the Governor too. In fact, rather than explain things, just swap your in. This will keep you roughly in the ballpark on your WOT shift points, just in case it is different.
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
