When driving I hear a high-pitched whining coming from the rear end whenever I put my foot on the gas. Any ideas as to what this is or how much it's gonna cost me in spring? Thanks
do you have a 5 speed? if so a little whinning is normal, but if this is something that has recently come on then it might be expensive. i had the same happen to me, and i had to end up getting a new rear-end. which worked out good in the long run. of sourse you might just have a gasket leak. check the fluid in the rear end
brharris27370
close
- Join DateMar 2001
- LocationRandleman,NC,USA
- iTrader Positive Feedback0
- iTrader Feedback Score(0)
- Car91 Camaro RS Convertible
- Engine385ci LT1 cnc ported heads big cam
- Transmission4L60E automatic
- Axle/Gears3.42 Zexel posi 7.5" rear
- Liked:0 Times in 0 Posts
if its an aftermarket gear it can whine. Both of my aftermarket gears whined. I wouldn't worry unless its something that the car didn't do before and has recently started or if it gets worse.
