Need a 10 bolt rear for 88 GTA 305'
Old Jul 21, 2009 | 08:14 AM
Dacman88GTA's Avatar
Car: 88' GTA with 19k on it.
Engine: 305 TPI WS6 Ram Air
Transmission: Automatic
Axle/Gears: 3:27 9 bolt aussie
I want to swap out my 3:27 gear ratio for 3:73, I have the rat 9 bolt, gotta swap the rears with a 10 bolt from a camaro 88 only I believe. Any suggestions?
Old Jul 21, 2009 | 08:26 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Need a 10 bolt rear for 88 GTA 305'
As I understand it, gears between a 9- and 10-bolt won't swap.
JamesC
Old Jul 21, 2009 | 09:47 AM
JamesC
That's right, they won"t, so the only way to upgrade the gear ratio is to change out the complete rear correct? I am looking for a 10 bolt rear that can accept 3:73 gears,from another firebird or camaro, how am I doing?
thanks for any suggestions James.
Old Jul 21, 2009 | 11:03 AM
JamesC's Avatar
Any thirdgen and/or fourthgen 10-bolt will work. Check the following FAQ for info that may be helpful:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Jul 21, 2009 | 11:52 AM
big gear head's Avatar
Why not just put a set of 3.70 gears in the 9 bolt?
I've got a disc brake 10 bolt that I could build if you are interested. It will need all new parts inside, but you would almost have a new rear end.
LilHot
South Central
Apr 13, 2026 11:46 PM
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
hectre13
Aug 26, 2015 08:17 AM
1nastygta
Aug 8, 2015 07:38 PM
