VSS/TC lockup/Speedo
Old Oct 31, 2001 | 12:05 PM
nicksL98's Avatar
If the Speedo in my 92 RS is goin wacky (bouncing) i assume there is a problem with the VSS or buffer. BUT If it is reading funny and sending the wrong signal will that cause the TC to lock/unlock sporadicly?
Old Nov 4, 2001 | 04:33 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
A friend of mine had that bouncing speedo problem. It turned out to be his speedo gears were worn. Once those were replaced, everything is good.
Yes, if the computer is getting wrong info about the speed of the car, it will do weird things with the TCC.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH (2.10 60')
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
