TH350 WITH LOCK UP OR NOT LOCKUP WHICH IS BEST
Old Nov 5, 2001 | 05:33 PM
Calderone's Avatar
Car: 87 Vette
Engine: 355/195AFR/SR/219CAM/1.6
Transmission: TH700R4/Vigilante
Axle/Gears: D44/3.45
Guys i wanna know what are the main differences in TH350 with lockup and another without lockup (pre 1979)
Are there performance differences ?
Both have TV Cables ?
Which year is stronger?
Old Nov 5, 2001 | 05:46 PM
transfixleo's Avatar
The actual trannies are esentially the same. The L/U one does have a higher volume pump but all shifts are the same. The good news is not too long ago TransGo came out with a Reprogramming Kit for the 350C that has all of the same features as the one for the 350. I talked to them years and years ago about it but they saw it as a fading unit but I guess they must have seen more interest in it.
Old Nov 5, 2001 | 06:24 PM
Jay 727's Avatar
The main differences are the pump, valve body, input shaft and converter. I have a 350c behind a 406 in a nova, it's converted to non lock up using a superior products kit and a pump, input and converter from a non lock up th350. The reason I converted it is because lock up turbo 350 high stall converters are more expensive than non lock up's and it's not a daily driver.
They all use the old style kick down cable and vacuum modulator.
jrdturbo
Mar 31, 2016 02:58 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
kkirch15
Sep 30, 2015 04:44 PM
Damon
Sep 26, 2015 04:29 PM
Dragonsys
Sep 25, 2015 03:51 PM
