transmissions
Old Jul 24, 2009 | 10:22 PM
chevykid7119's Avatar
transmissions
i have a 92' camaro with a 3.1L and 5 speed man. transmission I have recently got a 5.7L to put in it will my tranny bolt up to the new motor.
Old Jul 25, 2009 | 07:02 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: transmissions
Welcome to TGO. A search will provide more info or check the sticky at the top of the page, but the bottom line is that you'll need a V8 T-5.
JamesC
Old Jul 25, 2009 | 07:43 AM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: transmissions
Like James said, a V8 T5 is the best way to go.
That being said, if you're cheap(readoor) like me, you can make the V6 T5 bolt up. You'll need a V8 bellhousing, flywheel, pressure plate, and clutch fork. Either the V6 or V8 throwout bearing will work, but you should probably replace the one you have with a V8 bearing while you have it apart. You'll need a clutch disc from an 82 S15 w/ a 2.8 V6. Part # is CP4201 at Autozone, mine ran me $26 and had to be ordered. The hydraulic linkage will swap over and everything else will line up.
The only thing you need to do to the transmission is to shorten the input shaft by about 1/8", otherwise you will crack the bellhousing while trying to bolt everything together(ask me how I found that out). I recommend grinding a chamfer along the front edge after you trim it so it slides into the pilot bearing/bushing easier.
This setup is not as strong as using a V8 T5 due to the slightly smaller clutch disc size and the lower spline count of the V6 T5's input shaft. If you want to go with a proper 10.5" clutch disch, you can order one from Summit for $88+shipping. Part # is 384161.
