"Play" in the Drivetrain
Old Nov 5, 2001 | 11:12 AM
KeithO's Avatar
I drove my 88 IROC (All stock L98/700R4/Al Driveshaft/2.77 posi) on a road racing course on Saturday. About halfway through the day, I noticed that when I move the shifter into a "moving" gear (drive, reverse) there is a clunk/jerk in the drivetrain as if something has slop and putting it into gear tightens it up.
Understand that I often had to slam the car into second gear when heading into a turn and there is no way to soften the blow to the drivetrain (no heel/toe, etc).
I suppose it could be anything from the tranny through the rear end. Is there a known weak point in this layout? In what order should I do my search? Thanks.
Old Nov 6, 2001 | 11:37 AM
KeithO's Avatar
Anyone?
Old Nov 6, 2001 | 11:56 AM
Tom84L69's Avatar
Car: 84 Z28
Engine: L69: cam and porting
Transmission: T5, 3.73 rear
When road racing an automatic, you can try a left foot braking technique. With your right foot on the gas, you can sort of help the engine match revs, the same concept as heel toeing a manual.
As for your clunking, check the driveshaft at the axle, and keep in mind, some of this slop is normal.
Old Nov 6, 2001 | 06:06 PM
KeithO's Avatar
Thanks. I'll have a look.
Maybe I should also try the automatic transmission of heel-n-toe. I know I'm tearing the old girl up... ...but it's so fun!
Old Nov 6, 2001 | 10:16 PM
Tom84L69's Avatar
Car: 84 Z28
Road racing is the best, if you're ever in the Detroit area, check out Waterford hills.
here's the website.
www.waterfordhills.com
antman89iroc
36
Jan 31, 2016 08:42 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
rusty vango
Sep 29, 2015 02:44 PM
Bob88GTA
Sep 10, 2015 09:07 PM
