help with gear ratio
Car: 1984 firebird trans am
Engine: 383 stroker
Transmission: th350
Axle/Gears: 10 bolt posi with 373 ring and pini
Hello i have a 1984 firebird trans am it had the 305 ho l69 in it with a 700r4 today i tryed to see what my gear ratio was in my car but on my axel tubes i can not finde where it is stamped i have looked on the frount of the axel tube on the pasagner side by the carior and its not there dose anyone know where this migbe be hidding and if so can you pleace help me out i cant look on my RPO sheet cause it is missing also
Car: 91 RS
Engine: 350 TBI
Transmission: World Class T-5
Axle/Gears: 3.27 9-Bolt LSD
Re: help with gear ratio
you can always jack up the back of the car, put the tranny in neutral and count the amount of turns of the drive shaft it takes to turn the rear wheel ones.
but most people dont like that method
you could pull the diff cover and count the teeth on the ring and pinion gears and do the math, or sometimes its stamped into the ring gear. It never hurts to change your rear dif oil, alot of people overlook it during maint. Don't forget posi additive if required.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The following FAQ should provide some insight:
https://www.thirdgen.org/forums/tran...-10-bolts.html
IIRC, 84 was the only year for the L69 and autos. The manuals got 3.73's, but it "seems" to me that the autos got 3.42's.
JamesC
JamesC
Car: 1992 Camaro RS
Engine: 305 TBI
My 84 Trans Am had 3.73 with the 700R4. Many of the 84 f-bodies equipped with the L69 was usually matched to 3.73 regardless of which transmission. However that doesn't mean someone didn't change it or order the car with something different.
Hotrodboba400
Dec 10, 2019 07:07 PM
dbrochard
Sep 19, 2015 08:13 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
