From 3.08 to 2.73 s
Old Nov 7, 2001 | 06:07 PM
Calderone's Avatar
Car: 87 Vette
Engine: 355/195AFR/SR/219CAM/1.6
Transmission: TH700R4/Vigilante
Axle/Gears: D44/3.45
From 3.08 to 2.73 s
I have a 350 with a TH 350 on its way ...with a 3.08 rear ....i Broke my rear and i have set of 2.73 s what will be the effects if i change from 3.08 to 2.73 ?
Old Nov 7, 2001 | 06:16 PM
92RSFivePointSlow's Avatar
Car: 2002 Harley Nightrain
Engine: twin cam 88ci
Transmission: manual
not a whole lot, that's only a .35 decrease. If you don't have a posi, your car should run better times with the 2.73's. If you have a posi, you're probably not going to have a problem with traction with the 2.73's, but your engine will want to get out of the gears quicker then the rear will let it. Posi cars really shouldn't have any gear numerically lower then a 3.23, because when I swapped my 2.73's for 3.23's, my gas mileage DID NOT change, even on the highway.
F-body driver
Mar 6, 2023 11:44 AM
Numbah-1
Sep 12, 2015 08:57 PM
64Chief
Sep 12, 2015 08:05 AM
Mr. Chevy
Sep 11, 2015 06:06 PM
john204481
Sep 7, 2015 03:22 PM
