LSD/spool question
Old Jul 30, 2009 | 01:23 PM
HypnoToad's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
LSD/spool question
ok i have a 89 iroc rearend with the stock 3.23 gear in my car,well the lsd never works..it will everyonce in awhile,so figured it never rebulding.
well i know that pricy and im just wanting this thing to hook in straight line not building a roadcourse car.
so i wanna know can u put a mini spool in a LSD reaend?
Old Jul 30, 2009 | 01:46 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: LSD/spool question
No. A mini spool will only fit in an open diff. The carrier body is designed differently for a posi and the mini spool will not fit inside it.
The 7.5" mini spools are designed for dirt track racing where tire slip is common. They are not designed for drag racing or street use especially with your 26 spline axles.
Old Jul 30, 2009 | 02:03 PM
HypnoToad's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
thanks man,i figure it wouldnt work
i mean i just dont see it worth it to rebuild this reaend,since they seem to never really last anyways.....so i was thinking bout going the spool route on a 4th gen v6 or something.
Old Jul 30, 2009 | 02:26 PM
HypnoToad's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
well onething i dont get is my LSD works almost everytime in turns,or if turn it while i gun it will leave 2 marks..but never really works when going straight.
Old Jul 30, 2009 | 06:11 PM
big gear head's Avatar
You have an Auburn LSD, which is junk in my opinion. When they wear out they can not be rebuilt. You will have to clean out all of the metal sludge in the housing when you replace it. I recommend a new Eaton Posi to replace the Auburn. If it ever wears out (and it probably won't) you can rebuild it for about $110. Your '89 will probably have 26 spline axles. The Eaton is $445 plus the bearings and shims, which are $45. It's a lot of money, but you wil be spinning both wheels again. A spool is dangerous on the street and should only be used off road.
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
