wot in fourth
Old Jul 31, 2009 | 03:12 AM
derockz28's Avatar
Car: 1985 z28 90 VW Jetta ,90 VW Corrado
Axle/Gears: 4.11
wot in fourth
hey ive heard they make a valvebody that will allow me to go into fourth gear at wot for my 700. is there any truth to this and if so where can i get it? thanks
Old Aug 1, 2009 | 04:28 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: wot in fourth
not an entire VB, just a cheap little kit that goes in the VB, www.summitracing.com sells the B&M kit.
Old Aug 3, 2009 | 03:58 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Re: wot in fourth
FYI: (not totally sure on this) It will disable the kickdown from 4th to 3rd. If your in 4th and floor it, the transmission will not kickdown by itself to 3rd. You'll have to manually put it into 3rd, then floor the gas.
You can also modify you current parts to do the same thing. Search for the directions, I've posted them before.
Old Aug 3, 2009 | 05:09 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: wot in fourth
B7M claims 85% throttle for a kickdown, but I never measured. I do know when I stomped it at 50 mph, it'd go from OD to second.
Old Aug 3, 2009 | 05:29 PM
krisb410's Avatar
Re: wot in fourth
OK, well then maybe the "homemade" mod is what I'm thinking of.
junior419
Apr 7, 2025 11:35 AM
Pac J
May 17, 2020 10:44 AM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
dusterbd
Sep 29, 2015 08:40 AM
Damon
Sep 26, 2015 04:29 PM
