Vibration/buzzing in OD
Old Nov 12, 2001 | 07:51 AM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
I've had this weird buzzing /vibrating that seems to be coming from my 700R4 and it only happens when the car is in OD and at 60 mph or above. At first I thought it was the driveshaft but since it has been balanced and a new tranny mount has been installed and the problem is still there (although it is greatly improved with an OEM mount replacing the poly mount)I suspect it is the transmission. With the driveshaft out I noticed that the output shaft could be moved up and down a little bit. Is this normal or an indication of what could be wrong?
Mongoose-NCTGA-1990 Pontiac Formula/305 TBI-700R4 with Edelbrock Performer TBI intake,TES headers,and STB,K&N,MSD-6AL,Holley laser shot coil,Accel Extreme 9000 wires,Jet Stage 2 chip,TCI shift kit with corvette servo,Richmond 3.73 gear with Auburn 3 series posi,high flow cat,SLP 3" cat back,Eibach sportline springs,Energy Suspension poly throughout,Lakewood LCA and adjustable panhard bar package,SSM subframe connectors,IROC wonder bar,Tokico 5 way adjustable struts and shocks,Autometer electric fuel pressure gauge,Alpine,JL Audio,MB Quart,92 GTA taillights,92 GTA aero wing and hatch,Steve Spohn LCA relocater kit and torque arm,MacEwen White face gauges,84 T/A cold air induction air cleaner,Grant Formula GT wheel.
Old Nov 12, 2001 | 02:33 PM
Mongoose's Avatar
Car: 90 Formula
Does anyone know?
