aluminum driveshaft
Old Nov 13, 2001 | 02:41 PM
camaroman305's Avatar
aluminum driveshaft
what do you guys think about an aluminum driveshaft. apparently it shaves a few pounds off your cars overall weight
Old Nov 13, 2001 | 02:59 PM
Flash84Z28's Avatar
Car: '03 S-10/ '87 Trans Am
Engine: mild 350
Transmission: TH350
Not only do they shave a few pounds off you weight, they are lighter and easier to turn than stock steel? ones. I'm not a tranny guy but I think your tourque is transfered better with the lighter driveshaft. In otherwords the weight reduction is not as benificial as the preformance gain.
Hope this helps,
Matt
1984 Camaro Z28 - Black w/ Grey int.
-GM Goodwrench 350 with Edelbrock 600 Carb, Edelbrock Preformer RPM intake, AC Delco plugs, 8mm AC Delco wires, 14" Accel filter, Homemade Cold Air Indctn., Edelbrock Chrome valve covers, breather, and Air cleaner.
- Profesionally Built Turbo-350 with 2500 RPM Stall converter, Hurst shifter, & one wicked shift kit.
- Eagle Alloys 15" Alum. Rims surrounded by P235/60R15 BF Goodrich Radial T/A's
-Comming Soon:
3.73's, MAC Cat-Back, hollowed cat., B&M Megashifter, & Paint: Navy Blue Metallic w/ Silver strips
Pics at: http://members.fbody.com/flashz28/
Old Nov 13, 2001 | 03:09 PM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
Yes, Aluminum driveshaft,especially when used with Aluminum Flywheel, makes a difference you can feel as far as "in-gear throttle response" goes.Less rotating mass!
-Rich-
Old Nov 13, 2001 | 06:50 PM
now as far as quality goes, how would it last in the long run? WOuld it be worth switching to aluminum?
Old Nov 13, 2001 | 08:27 PM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
save your money. i really doubt that you will see a big difference.
1991 Firebird
350 L98 (was a 305 TBI),T-5,Edelbrock TES and cat back,Accel manifold
NOS,subframes,jegster torque arm,MSD Digital 6
AFPR,Lakewood lcas
Hurst linelock,SLP cam (206 212 .480 .486),relocated battery,cold air,Hypertech chip,centerforce df,clutch
poly bushings and mounts
AFR 190s
Harland sharp 1.5 rockers
autopower rollbar
12.33 @ 114.83 juiced uncorrected
13.510 @ 102 non juiced uncorrected
Linson
Oct 24, 2025 02:00 PM
loud91rs
Oct 5, 2015 10:05 PM
