3.42 gears or 3.73 or 4.10
Car: 1986 z28
Engine: 350 from 305
Transmission: t5 borg werner
I have a 1986 Iroc that I pulled out a 305 and went 350. I kept the t-5 and its geared well with the stock 3.42 gear. The car would run like a raped ape, but spun too bad. I recently put in a posi chunk and had to get new gears because the chunk I got needed thick gears so I got 4.10. I am just wondering if anyone knows if I would get better performance from a different gear. The 4.10 seems to go through the gears quickly (45 mph in 4th gear). I would like to know if Im wasting power by having this gear. And what gear should I have. Thanks
Re: 3.42 gears or 3.73 or 4.10
I prefer the 3.42, worked well with my 700r4.
I think the ones behind the t56 in the other car are 2.73 or close to that. Even with that the t56 first gear feels much lower than a t5 with similar gears. Forgot what the first gear ratio is on the t56.
4.10 just demands to many rpm for me.
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Whats the engine combo? 4.10 is too much gear for most small blocks out there, especially anything stock or close to stock. 3.42 is generally considered the best all-around gear for a street car with a near-stock small block.
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
i think the 3.27 gears are excellent for a built tpi and a built 700r4... i think the 3.42 are a tad high for my setup....
Car: 89 IROC
Engine: 6.8 HSR N2O
Transmission: TKO 600
Axle/Gears: 9" Moser 3.50 True trac
I've run 2.77, 3.27 and 3.70's in my 9 bolt. I really liked the 3.27's for auto and then T5. I recently went with a 3.70 since they are about the only new gear set available for my rear. I must say that the 3.70 was the best so far. My engine is well built but still redlines at 6k. The 3.70 (or 3.73 for your 10 bolt) is a good all around set to me. Actually I wanted the 3.42 but couldn't find a new set without ordering it from Australia. I thought the 3.70 would be a little low but it's not that different from the 3.27 for everyday driving. But, the 3.70 is much better at the track. Worth around 3 tenths a second in the 1/8 mi for me. I think the lower rear is easier to get off the line with a stick shift. On the street is a different story as 1st gear has to be pedaled quite a bit to avoid massive tire spin! I don't think I hit full throttle on the street til about 5 grand in 1st.
Hotrodboba400
Dec 10, 2019 07:07 PM
dbrochard
Sep 19, 2015 08:13 PM
georgiaslim45
Sep 9, 2015 08:12 PM
georgiaslim45
Sep 9, 2015 08:11 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
