driveshaft th350
Old Aug 10, 2009 | 08:11 PM
curacaoz28's Avatar
Car: 1985 Iroc-z28(sold) 1994 camaro z28
Engine: 350lt1
Transmission: 6-speed manual
Axle/Gears: ???
driveshaft th350
Hi,
like you can see I have a th350(6'' tail) under my car. I got a 82 driveshaft with it that vibrate a bit at hy speed 100 km/h +.
Is thee any allumium driveshaft from any chevy with that lenght that I can use. because the ones on 4th gens are shorter.
Old Aug 10, 2009 | 08:31 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: driveshaft th350
I don't think the aluminum driveshafts were available for the 200C transmissions, which is the longer driveshaft. You'll need to get the one you have balanced, find another or get a new one made. Last option is to install a 9" tailshaft TH350 so you can use the readily available aluminum driveshaft.
Old Aug 10, 2009 | 08:52 PM
curacaoz28's Avatar
Engine: 350lt1
Axle/Gears: ???
ok, but trans works fine so I will not going to take it out after all the troublr I've been tru
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
loud91rs
Oct 5, 2015 10:05 PM
romcjr
Sep 17, 2015 05:18 PM
89newfun
Sep 16, 2015 09:28 AM
