Reinforce chassis for T-56 x-member
Car: Bone stock 1989 Iroc T-Top,1991 Z28
Engine: 5.7, Carbed 383
Transmission: 700r4, T-56
I was doing some searching and came up with this from a post in the fabrication section:
"Having seen a few subframes rip open in that area on T56 conversion members because you’re shifting the weight to a part of the frame that was not reinforced for the tranny or TA load I’d actually consider adding some reinforcing plates there, or if I wasn’t worried about a weld in install I’d make the angle iron parts weld on saddles to the subframe with a captured bolt in piece for the actual cross member."
I will be running a Skulte LT x-member and adding a shackle type TA mount for a UMI Adjustable TA. Engine will be at least 500 fwhp. Any suggestions/comments? Post is here:
https://www.thirdgen.org/forums/fabr...-tube-t56.html
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Re: Reinforce chassis for T-56 x-member
The Xmem actually carries very little weight. Also, the comment that a T56 moves weight on the frame is incorrect, the T56 xmem mounts in the exact same location as all the other xmems, the frame load is exactly the same.
My $0.02... Spend your time & $$ on something else.. This is a non-issue..
darwinprice
17
Oct 11, 2015 11:51 PM
tonys91rs
Oct 10, 2015 03:31 PM
[CA] 700R4 trans & parts
6998poncho
Sep 25, 2015 02:56 PM
Ragtop Man
Sep 12, 2015 12:23 AM
