700r4 probs.
Car: 89 formula
Transmission: t5
Axle/Gears: open junk
700r4 probs.
got a 86 iroc, started as a tpi car, but now its carb'd, the problem is when i put it in drive it doesnt move, or even try to move, and yes its full of fluid. There is 3 wires that go from the tranny into the main harness, they are green, tan/blk, and pink, what do these wires do?
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: 700r4 probs.
Those connect to the 4th gear solenoid to lock up the torque converter - wouldn't have anything to do with the tranny slipping. With the carb swap, has the TV cable been reconnected properly, correcting the geometry so that it functions as it should? This is critical, if it's not correct the tranny can and will burn up fast.
[CA] 700R4 trans & parts
6998poncho
Sep 25, 2015 02:56 PM
