Posi? Will it work in my car......
Car: 1992 RS
Engine: 3.1L V6
I recently found a wrecked 92 z28 and the guy said it has posi. I really want posi because I am tired of running one tire out before the other. Could I take the posi unit from the z28 and just put it in my car? Would I have to change my gears as well? And is this a hard job to do? Thanks if anyone can help!
1992 Polo Green RS 3.1L
Just working on making it look good for now...
"So you have an eight?"
"BIG DEAL!"
"BIG DEAL!"
swap the ring gear from your car onto the posi carrier install it and chack for proper back lash and you'll be set.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
ICON Motorsports
1st & 3rd
Transmission: 4L80E/4L80E
If the gears in his rear are acceptable to you, change out the whole rear. Much, much easier.
Besides, if your gears are a different "series" than his (as in one a 2-series and the other a 3-series), the gears won't swap between the carriers, anyway.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4, 2300 stall TC. Ported World 305 heads, Crane PowerMax 2050 cam. ZZ3/4 intake, oil pump, pan & baffle. Accel HEI SuperCoil & module. Hooker 2055 headers, 3" Catco cat & 3" catback w/dual-opposite Flowmaster 80. 2.93 limited slip. Spohn SFCs waiting to be installed. AMSOIL syn lubes bumper-to-bumper. Daily year-round driver. Best ET, speed TBD...
57 Bel Air, my 1st car. '66 396, 9.7:1 forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 700 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
