I need a strong replacement for T5
Old Nov 29, 2001 | 11:28 PM
92birdman's Avatar
I am about to buy a 350 bored .60 over and stroke it, so my T5 will have to go. Does anyone have any recommendations on good, strong replacement 5 speed tranny's?
Old Nov 30, 2001 | 02:21 AM
MidnightZ's Avatar
I suggest looking at getting a Tremec. They are just about the strongest manual transmissions you can find. Shouldn't have any trouble running it with your engine. You can check them out at http://www.fortesparts.com/tremec/index.html
Old Nov 30, 2001 | 07:05 AM
TPI Guy's Avatar
Car: 1968 Camaro
Engine: 406
Transmission: Tremec TKO
I like the Tremec TKO. I bought one with a pro 5.0 shifter from Forte's and I am still in love.
355 c.i.
Dart 180 Heads
Lunati 224/224 cam
Harland Sharp 1.5 rockers
Performer RPM Manifold
Holley 600 cfm double pumper
Hooker Super Competition Headers
Flowmaster Exhaust
Competition Engineering Sub-frame connectors
Tremec TKO
Pro 5.0 Shifter
GM posi 3.42 rear
Hurst Roll Control
13.9@102
http://www.geocities.com/thetpiguy/index.html
chemjoker@aol.com
Old Nov 30, 2001 | 08:45 AM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
T56 from a 94-97 F-body is another good choice.
Old Nov 30, 2001 | 10:18 AM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Axle/Gears: 10 Bolt 3.73
I plan on gettin the Tremec TKO, early next year.(probably March).This thing's rated for way more torque than it'll ever see in my car.
I like that.
-Rich-
Old Dec 2, 2001 | 12:28 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Tremec, Richmond, and T56 are your choices. None of them is cheap.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH (2.10 60')
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
Old Dec 2, 2001 | 04:48 PM
xxwarrior36xx's Avatar
I have a T56 and have had no problms with it. If you are going to spend money you should get a 6 speed. These aren't cheap but you can pick up a used one alot cheaper. They are extremely under rated if you have alot of power so it should hold.
specialized
Jun 18, 2022 09:26 AM
cam-mike
Aug 24, 2015 07:23 AM
chazman
Aug 22, 2015 02:01 PM
