transmission kickdown
Old Dec 1, 2001 | 02:54 PM
southerndude_31's Avatar
we have an 86 camaro that we had a 2.8 in it
we swapped in a carberated 350 with no electronics but hei
the problen is whenever you let off the gas to slow down or come to a stop the transmission act as though it is still in gear and lurches
Old Dec 2, 2001 | 12:20 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
What transmission do you have in it now? If a TH700R4 or TH350C, did you hook up the lockup function in some fashion or another?
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4, 2300 stall TC. Ported World 305 heads, Crane PowerMax 2050 cam. ZZ3/4 intake, oil pump, pan & baffle. Accel HEI SuperCoil & module. Hooker 2055 headers, 3" Catco cat & 3" catback w/dual-opposite Flowmaster 80. 2.93 limited slip. Spohn SFCs waiting to be installed. AMSOIL syn lubes bumper-to-bumper. Daily year-round driver. Best ET, speed TBD...
57 Bel Air, my 1st car. '66 396, 9.7:1 forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 700 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Old Dec 2, 2001 | 07:48 PM
its 700r4 and thereis no kickdown hooked up at all
Old Dec 2, 2001 | 08:09 PM
oops i meand lock up hooked up at all
i was really just wondering if anyone has ever heard of a lock upo torque con. staying locked up and if they did what were the symptoms
Old Dec 3, 2001 | 02:45 PM
transfixleo's Avatar
It can stay locked but would disengage as soon as you dropped out of 2nd gear. You could try manually downshifting out of second and see if it does it still. does it while in 1st. If not then that cuold be the problem.
Old Dec 3, 2001 | 05:10 PM
thats exactly what it does as it downshifts to first from second or to second from third
or od to third
Hotrodboba400
Dec 10, 2019 07:07 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
TX-SleeperC5
Sep 24, 2015 03:13 PM
Youngs92
Sep 23, 2015 11:29 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
