what size rear axle
Old Dec 3, 2001 | 10:22 PM
1986CamaroIROC-Z's Avatar
what size rear axle
I have an 86 IROC-Z and need to know what size the rear is...is it a 10-bolt...8.5 inch?
1986 Metallic Blue IROC-Z
80k miles, 305 TPI
Mods:
-Edelbrock Hi-Flow baseplate
-Dynomax Cat-back
-gutted MAF
-K&N's
-airfoil
-shiftkit
Old Dec 3, 2001 | 10:29 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Commonly called the 7.5", yours should actually be a 7 5/8". 86 was the changeover year to the larger ring gear. Both are interchangable.
The 8.5" 10 bolt was never offered in a third gen unless you have a metal plug in the rear cover. Then it's a Dana44 which is a 8.5" but I really doubt you have that.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.447 altitude corrected to 10.99
Best MPH on a time slip: 119.42 altitude corrected to 124.86
Altitude corrected rear wheel HP: 493
Best 60 foot: 1.586
Racing at 3500 feet elevation with a typical race day over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Dec 4, 2001 | 12:24 AM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
Could be a 9 bolt too. The first year for Iroc 9 bolts was either 86 or 87.
Miles
88 427 Big Block Camaro
(Best 1/4) 12.18 @ 113mph 1.75 60ft
(Best 1/8) 7.76 @ 94mph 1.72 60ft
Currently installing 3.73's into my 9 bolt (YES, it is a 9 bolt & YES they are 3.73's, not 3.70. I currently have 4.10 gear sets and new series 3 posi carriers for sale for 9 bolts )
www.koolmeister.com
Old Dec 5, 2001 | 12:11 AM
I have the 2.73 posi rear right now with the 7.5inch...and want to upgrade to 3.42's. Found richmond gears on the summitracing site and they are for:
GM: 10-bolt, 7 1/2 in., 7.625 in., 3.42 ratio, 2 series: carrier, ring and pinion
WOuld these work? and do i need an installation kit?
80k miles, 305 TPI
Mods:
-Dynomax Cat-back
-gutted MAF
-K&N's
-airfoil
-shiftkit
Old Dec 5, 2001 | 05:56 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Yes, those are it. If you are installing the gears yourself, I'd get the kit. If somebody else is doing (somebody who does rears professionally I hope) then they should already have shims and such, so I wouldn't bother.
If you live in Southeastern US, check us out!
South East Thirdgen
1987 Trans Am 305
14.88 @ 92.81
customblackbird
Aug 15, 2021 10:16 PM
toronto formula
Nov 10, 2015 06:17 AM
69 Six Pack
Oct 5, 2015 07:51 PM
E Rod
Aug 28, 2015 05:17 AM
knight72
Aug 10, 2015 09:32 PM
