5sp is in! (pics)
Old Aug 29, 2009 | 12:57 PM
s10irocspikes's Avatar
Car: 86 IROC
Engine: 350 Miniram
5sp is in! (pics)
Thanks to everyone here for helping me through all the questions and problems I had along the way. Everything turned out great aside from the plastic clip/bushing that broke. The piece that secures the master cyl. arm to the clutch pedal. It was easily repaired with a c-clip.
Here's the finished product:
Surgery^^^
Clutch^^^
Trans^^^
DONE!!!!
Old Aug 29, 2009 | 01:01 PM
Car: 86 IROC
Engine: 350 Miniram
Re: 5sp is in! (pics)
How much did it cost???
Shifter (Pro 5.0): $180
Clutch kit (Zoom): $280
Hydrolic system with hardware (ebay): $108
Shifter plate (ebay): $67
Torque arm mount and hardware (ebay): $64
Pedal assembly (ebay): $100
Flywheel (GM Performance): $290
Flywheel hardware (ARP): $15
Pressure plate hardware (ARP): $12
Trans fluid: $8
Transmission: $160
Total: $1,284
One less headache: Priceless
Now I can drive her
Old Aug 29, 2009 | 02:34 PM
RED_DRAGON_85's Avatar
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
I WANT A MANUAL SO BAD!
looks good.
enjoy your new trans
Old Aug 30, 2009 | 07:39 PM
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
Your car does look good, especially w/ those rims.-- I just picked up a T5 to swap in. I can't wait to get it on the road!
Old Aug 30, 2009 | 07:53 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Looks like fun! How much more fun is it to drive now? Also, you think the tranny is going to hold with your engine?
Old Aug 30, 2009 | 08:58 PM
joshsz28's Avatar
Car: 87 IROC
Damn am I jealous, I recently tore up my auto 700r4 so I'm looking to throw a t5 in it.
Wish me good luck!!
Old Aug 30, 2009 | 09:59 PM
Car: 86 IROC
Engine: 350 Miniram
Thanks for the comments. The car is definately more exciting to drive now.
As far as longevity, i'm trying hard not to beat her as this is my only means of transportation for now. I have ripped on her a couple of times and she flies through the gears no problem. Already raced and beat a WRX STi, Audi S4, and third gen Formula. The Zoom clutch works nice. I think by going to a lighter flywheel (16lb.) it's not sending as much shock to the drivetrain but that can be good or bad. Bad as in less inertia torque, not sure yet. Haven't had any problems. But good as in more hp up top and waaay quicker revs. The Pro 5.0 shifter is really precise. Highly recommend.
I've also herd about taking it easy on third as this is the weak spot. Alot of times my friends killed t5's when slamming third.
As for all you attempting the swap, do it! The hardest part was taking out the auto (messy) and the pedal assy. (cramped). Just take your time and triple check your measurements before you cut. The t5 is soooo simple to swap out should you need to. Good luck.
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
TexasFormula
Sep 30, 2015 06:36 PM
aaron7
Sep 30, 2015 09:15 AM
92projectcamaro
Sep 29, 2015 07:07 PM
82xCAMAROxZ28
Sep 27, 2015 12:31 AM
