How to replace Spider Gears (7.5" 10 Bolt)
Old Sep 9, 2009 | 01:08 PM
OSS's Avatar
OSS
Car: 1985 Trans-Am
Engine: 305 LG4 4bbl
Axle/Gears: 3.27 Limited Slip
Hey TG.org OSS here;
I blew my rear end in my '83 Z28 last month, so I bought a set of gears today. Unfortionatly, I have no idea ho to get the spider gears inside the carrier. I have the axles out already. She's a limited slip 3.42. I noticed the 4 springs and the spring 'housing' all over the place, broken too...Once I get the spider gears back in, will I need the springs? If I dont use the springs (housing is snapped) would the rear end act like an open diff? Thanks in advance. Hopefully someone can help in the next hour or so! Im outside working now hah...
Old Sep 9, 2009 | 02:21 PM
big gear head's Avatar
Re: How to replace Spider Gears (7.5" 10 Bolt)
If you have springs then you probably have an Auburn. If you didn't get parts for an Auburn then you wasted your money. If the axle gears have cones made on them then you probably got Auburn parts. If they have no cones then they will not work. For the most part the Auburn isn't rebuildable. Most of the time you just have to replace it. It is important to know which differential you have. Find out which one you have and post again.
Old Sep 10, 2009 | 10:29 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
And if you have the power and traction to break that, then it's time for a 12 bolt, or Ford 9-inch, or some stronger rear end anyway, or you'll be breaking stuff again, soon.
hectre13
Dec 11, 2023 08:14 AM
Reddeath210
Oct 6, 2015 08:20 AM
hectre13
Aug 26, 2015 08:17 AM
mizz0313
Aug 12, 2015 06:45 AM
