700r4 help please!
Old Sep 27, 2009 | 01:45 PM
jpearsall187's Avatar
700r4 help please!
I have an 88 Camaro IROC-Z 350 TPI with a 700r4. The car has been sitting for several years. I got it running and put in fresh tranny fluid and a filter. Also, I noticed the TV cable was not attached, so I rigged it with some wire and adjusted the cable. Here is what happened: until today, the car would shift into first and second, but then wouldn't shift into third, the RPMs would just shoot up. Now, the car seems to be stuck in park. I can move the shifter, but reverse, neutral, overdrive, drive, 1, and 2: none will engage. Anyone have any ideas? Could these two problems be related?
Old Sep 27, 2009 | 03:19 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: 700r4 help please!
You should ask Pro Built Automatics he might be able to help you good luck.
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
