slips a little between 3-4 shift
Old Oct 5, 2009 | 09:48 PM
1fastam's Avatar
Car: 1991 transam
Engine: 305 30 over long tubes into 3" y
Axle/Gears: 4:10
hey fellas, gotta 700r4 that just started acting weird.never slipped before. i put a set of l/t headers on it started to slip between 3-4 shift. doesnt slip unless im getting on it kinda hard. i replaced the filter and fluid today. changes harder than it ever has in1-2 shift 2-3 is about normal, 3-4 slips for a couple seconds goes in gear pulls fine unless i get on it . im thinking it just needs rebuild, but i thought id ask here. maybe im missing something. i adjusted the tv cable a couple times to be sure it was right. normal driving it changes great.any ideas would be great ,thanks for the help,jimmy
Old Oct 6, 2009 | 07:02 PM
Badass355ciz28's Avatar
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
Re: slips a little between 3-4 shift
sounds like either a pressure issue due to a seal leaking internally or 3/4 clutch pack is wearing out.......... mine did the same thing. had to replace the 3/4 clutch pack........... simple task to do....and make sure the tv cable is correctly adjusted
Old Oct 7, 2009 | 08:05 PM
1fastam's Avatar
Car: 1991 transam
Axle/Gears: 4:10
im rebuilding it went out completely last night(3-4) thanks for the help guys, its appreciated,jimmy
jrdturbo
Mar 31, 2016 02:58 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
racereese
Oct 3, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
6998poncho
Sep 25, 2015 02:56 PM
