Aluminum Flywheel
Old Oct 7, 2009 | 03:34 PM
Tyrel2018's Avatar
Car: 1989 Camaro RS
Engine: LO5 350
Axle/Gears: 3.42 posi
Aluminum Flywheel
my dad was out at my grandpas this weekend and he found 2 hays aluminum flywheel out there. i was wondering how much they are used and if anyone on here has one and if they noticed a difference. i also wondered what are the pros and cons of using aluminum to steel. thanks Ty.
Old Oct 7, 2009 | 07:15 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Aluminum Flywheel
if they are used, forget it.
they will help the engine rev faster, but a heavyer wheel will not loose as many rpms when shifting and usually launch better.
do you even know what kind of engine they are for and how make teeth they have?
Old Oct 7, 2009 | 09:28 PM
Tyrel2018's Avatar
Car: 1989 Camaro RS
Engine: LO5 350
they are for a 400 sbc and they are both 153 tooth.
Old Oct 8, 2009 | 10:51 PM
Tyrel2018's Avatar
Car: 1989 Camaro RS
Engine: LO5 350
anyone ever use an aluminum flywheel?
Old Oct 9, 2009 | 05:22 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
I've used a 153 tooth alum. flywheel behind a 400. It's revvier. On the street, I wouldn't necessarily go that light. I like the lighter (~16lb) 305 TPI flywheel just fine.
Old Oct 11, 2009 | 03:15 PM
Pro Built Automatics's Avatar
Aluminum flywheels are hard on clutches when used on the street without a steep first gear (total of 12 to 14-1) ratio. Once rolling, they are actually easier on everything else, and the car will accelerate quicker. They are great for road racing.
Old Oct 11, 2009 | 03:45 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I'm using the above as well.
JamesC
Linson
Oct 24, 2025 02:00 PM
mfp189
Sep 27, 2015 09:25 AM
