Going from 200c-700r4
Old Oct 11, 2009 | 11:31 AM
ranger77's Avatar
Car: 82 firebird
Transmission: i believe 200c
Axle/Gears: 3.43 Posi
What will i need to do to replace my 200-c hydromatic transmission with a 700r4. What other items would i need along with the transmission.
On the side note i heard some 700r4 are 3-speeds but its comming from a 86 camaro so i take it that its a 4 speed?
Old Oct 11, 2009 | 05:12 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: Going from 200c-700r4
will need the 700 r4 driveshaft and crossmember,as i
remember you have to drill 1 extra hole to use the 700
r4 on an '82 and hold a nut on the other side to mount
the crossmember.Other parts that may be needed are
shifter,shift cable,shift plate, 700r4 torque arm,
possibly 700r4 throttle cable,speedo cable,cooler lines.
the '82 floor pans are slightly different from '83 up,but
don't know if it makes a difference swapping '83 up
parts to an '82.
My car went from super t-10 to turbo 350 to 700r4
Old Oct 11, 2009 | 05:36 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
i sure wish someone would tell us 100% what is needed to do this, i know its been done time and time again
Old Oct 11, 2009 | 06:45 PM
ranger77's Avatar
Car: 82 firebird
Would a th-350 be a easier hook up then? cause what ever is easier id like to choose.
Old Oct 11, 2009 | 09:20 PM
Iroc-Z28Man's Avatar
Car: 86 Iroc-Z28 Camaro/84 BMW M Power
Engine: 350TPI/ S50
Transmission: t-5 five speed/ 5 speed
Axle/Gears: 3.42 posi/ 3.73LSD
This is a long shot but do you live near pittsburgh? Because i have a Good 700r4 for sale with everything listed by 8t2 z-chev except for the crossmember touque arm and speedo cable. PM me if your interested.
