th350 instant direct drive
Old Oct 16, 2009 | 05:06 PM
lucas1979's Avatar
So i just finished installing my th350 after a rebuild in my 79 t/a and i'm having problems with 1st and 2nd.
When i come to a stop and let off the brake i can tell it's in first as for about half a second when i press the throttle it will lunge forward like it always has since i've owned it. Then it instantly shifts to 3rd gear and stays there.
When i manually shift to 1st (Low on the shifter) it will do the same thing except instead of going to third, it seems to go to neutral or somehow engage? the clutches so that it will not actually move the car
My question is this: could it be anything besides the vacuum modulator on a th350? does the detent cable really not matter on these 3 speed autos like it does on a 700r4 or another overdrive auto?
right now my detent cable does not want to move at all unless i have the sleeve out of the detent slot.
e.g. i can pull on the connecting rod that goes into the valve body assembly if the sleeve is off, but once attached, the rod will not move up into the sleeve.
perhaps my understanding of how a detent cable is supposed to pull this rod is wrong.
please help me, my car will move but i don't want to hurt the transmission as it's always been reliable for me
Old Oct 16, 2009 | 10:00 PM
sgt473's Avatar
Car: 87 Z28
Engine: LB9
Transmission: 4L60
Axle/Gears: 2:73
Re: th350 instant direct drive
The detent cable is just for passing gear. the modulator is the torque sensing element to tell the trans how much load is on the engine so the proper pressure is obtained. Was a shift kit with a dual feed installed? If the detent is not fully closed the trans will stay in first gear for a longer time. How was the clearance on the intermediate clutch pack? was the pump replaced? Was the intermediate over running roller clutch installed and tested prior to assemble. If the mechanical parts are correct, you should have manual low and it should shift into second manually but at a higher speed, if the modulator, governor, and detent are adjusted some where close. Thats all I can think of now, hope it helps
Old Oct 17, 2009 | 03:13 PM
lucas1979's Avatar
no shift kit, it's all stock parts, the clearance on the clutch pack seemed fine to me, and it was the same amount of steels as in the original assembly, stock pump as well
i'm not sure about the over running roller clutch, i didn't have any tools to test anything while i was putting it together
a combination of the governor, modulator and detent were my first thoughts, you are saying that it won't manually shift into second unless i'm at a certain speed?
Old Oct 17, 2009 | 04:15 PM
sgt473's Avatar
Car: 87 Z28
Engine: LB9
Transmission: 4L60
Axle/Gears: 2:73
If the trans is assembled correctly a manual upshift from first to second will varrify this. If the governor is working properly and the modulator has vacuum it should still shift manually, even if the detent is way out of adjustment. Did you replace the valve body gaskets if so did they match up with the original ones. Did you install the pump gasket correctly? Did you check the bolts on the steel plate in front of the valve body? Hope this helps
Old Oct 17, 2009 | 04:20 PM
lucas1979's Avatar
i am 100% sure the gasket was correct and the bolts were torqued properly, i checked and triple checked them
the vacuum modulator might not have vacuum as i think i have it hooked up to a thermal vacuum switch on the intake right now, and i read it is supposed to be hooked into the same vacuum as the brake booster?
i'm not sure i stated this in my OP, but when i manually shift into first, after i give it any throttle it feels as if the clutches engage (relating to a manual here, so it's like being in neutral) and i no longer have forward motion when i press on the throttle, it just rolls
i am going to try it with the vacuum modulator unhooked, then with it hooked into the brake same hookup as the brake booster and see how that goes, if i can get 1st gear to work that way, i will also try a manual from first to second
or should second work regardless of this little 1st to neutral problem?
Old Oct 17, 2009 | 06:15 PM
lucas1979's Avatar
i just tested manual first second and drive, in first it's not as i thought, it's more i push on the throttle then it feels as if the brake is on when i give it more throttle
when i shift into second it feels like second gear, takes a lot of work to move from stop, but it does work
i changed the vacuum modulator line to a different intake vacuum outlet with no change, but i didn't adjust it either (it is indeed an aftermarket brass can small style)
reverse works just fine as well, partial throttle or full, it will move it and spin the tires as it should
Old Oct 17, 2009 | 08:38 PM
sgt473's Avatar
Car: 87 Z28
Engine: LB9
Transmission: 4L60
Axle/Gears: 2:73
How many intermediate clutch plates did you install? Was the trans from a 5.7 or a 5.0? Most 5.0's and six cyls have 2 usually the 5.7 have 3.
If it dad 2 fiber clutch plates and you added one this could be the problem. The intermediate clutch pack for a 5.7 should have 1 thick pressure plate 3 fiber driven plates,3 thin steel plates and one wave plate. The modulator should have manifold vacuum not ported. I you remove the pan you should be able to see the intermediate clutch pack from a small hole in the bottom of the case near the pump. You can check the clearence with a feeler gague. should have at least .060 clearence. Look for burned fluid and any signs of debris in the pan. By any chance did the modulator valve fall out when you had the trans apart?
Old Oct 17, 2009 | 10:35 PM
lucas1979's Avatar
it's from a 6.6 olds 403
in the intermediate clutch pack i have the cushion spring, 4 steels and fiber plates then the pressure plate on top of them
the modulator i never took out until i finished all the internal clutches' assembly, then i took it out to clean before putting it back and putting together the valve body
before i took the transmission out to repair, i had a blown front main seal and sometimes i would have very hard shifting when in D from a stop, it would rev as if in neutral and then hard shift into first at around 1000......i don't know if this information helps at all
thank you for all your help so far sgt473
Old Oct 18, 2009 | 04:51 PM
sgt473's Avatar
Car: 87 Z28
Engine: LB9
Transmission: 4L60
Axle/Gears: 2:73
The 4 steel plates may be a problem. the only time I use 4 steels is when I remove the cushion spring for a firmer 1-2 shift.and add one steel. On most 350's there isn't enough room for an extra steel and a wave. If the original problem is usually caused by a pressure loss. some time the screen bolts loosen and some time you get an air leak in the suction side of the pump low fluid causes the harsh engagement when revving the engine. For first gear in drive range the forward clutch is applied. Second in drive range the intermediate clutch applies and locks the over running roller clutch. third gear the direct clutch comes on and the intermediate clutch is in effective. Unless check ***** were miss installed and the clutched were assembled incorrectly the problem reverts back to the intermediate clutch pack. The trans does have a 1-2 accumulator but the original problem of not going into gear would not cause a problem in second. The part I don't understand is when you say it feel like the brake is on, that can only happen if two elements are applied at once. Meaning the direct clutch and the intermediate clutch, at that time the clutch with the most surface area destroys the other and it does feel much like the breaks are applied. That's pretty much how a trans brake works.It locks the trans in two gears at the same time . Also the trans may feel sluggish when starting from a dead stop, like a second gear start. Hang in there.
Old Oct 19, 2009 | 07:25 PM
lucas1979's Avatar
you are exactly right, if in D it will do a .5 second lunge in low/1st gear then shift directly into second and stay there no matter my speed (i can't get into 3rd at this time)
if i shift into manual Low/1st it will feel like that braking action i described after the same .5 second lunge
it sounds like it's definitely going to be a pull and disassemble job at this point, which is what i was hoping to avoid
as for the amount of steels i was mistaken and talking about the forward and direct clutches, i'm not sure about the intermediate and i will have to take a look at that
the checkballs i know are right as i had the holes marked previously and doubled checked with the metal plate layed atop of the valve body
sorry for running back and forth and all around on the symptoms of this
the braking that seems to be going on in manual 1st guarantees a clutch pack problem am i right? or could that still be a problem with perhaps shift valves not being where they are supposed to and allowing fluid to bypass?
Old Oct 19, 2009 | 08:31 PM
sgt473's Avatar
Car: 87 Z28
Engine: LB9
Transmission: 4L60
Axle/Gears: 2:73
When you take it apart again, look at the governor bore, double check the clutch packs. If it's an 8 cylinder trans you should have 5 forward 4 direct and 3 intermediate driven clutched( fiber plates). Look for any signs of hot spots on the steel plates, look at the hub on the torque converter, check for excessive ware. Look real close at the pump bushing, you said it blow the seal, if in doubt replace the bushing and check the fit on the converter hub.If the valve body wasn't taken apart there shouldn't be a problem. varify that none of the valves are stuck. check the sealing rings on the back of the pump, sometimes a broken ring can cause a cross leak especially on the direct drum. Make sure the governor valve moves freely. Let us know how you progress?
Old Oct 19, 2009 | 09:06 PM
lucas1979's Avatar
when i replaced the seals on the pump it's possible i missed one, i know i had gotten steel rings (i think) and not the standard teflon, i put 2 of the teflon back on as they were skinnier and i didn't have replacements, would it be better to just go buy some teflon or replacement steel ones so i have them all for sure?
Old Oct 19, 2009 | 09:22 PM
sgt473's Avatar
Car: 87 Z28
Engine: LB9
Transmission: 4L60
Axle/Gears: 2:73
The rings are different sizes if i remember correctly. there are two for the forward drum and there for the direct drum. I like the older rings. The teflon some times pose a problem in very cold weather. Before you reassemble the trans you can stack the drums on the pump upside down and air check to make sure all is well I usually do this to every trans, Some one here may have a blow up of the pump to identify the oil feed holes where you blow the air 90 pis will do the clutches should apply with very little air leakage.
Old Nov 6, 2009 | 09:50 PM
lucas1979's Avatar
sorry for taking so long to get back here and post again, i was in the middle of a move when this happened, probably part of the reason it did as the rebuild was sort of rushed
anyway, after moving the car to the new house, i did a manual drive in second and it drove normally, then shifted to D and it kicked into direct drive (third) so now all that's missing is first gear, sorry again for the mis-diagnosis, but am i still looking at clutch packs with only the first gear shifting far too early, and when in manual seemingly shifting out or losing fluid?
my thought is that it might be a mis-aligned valve or something in the valvebody not moving freely or properly, and directing fluid where it shouldn't go
Old Nov 6, 2009 | 11:29 PM
sgt473's Avatar
Car: 87 Z28
Engine: LB9
Transmission: 4L60
Axle/Gears: 2:73
If you start in manual 1st and shift to 2nd then go to third. Will it hold 1 st gear until you shift? If every thing works ok manually and doesn't slip in any gear including reverse you may have a governor or valve body problem. happy hunting
Old Nov 6, 2009 | 11:36 PM
lucas1979's Avatar
well in manual first it has what feels like a braking action, at first throttle it will move, then change to the braking, as if it's being held back, when in drive, it does the same delayed action, but instead of the braking, it just shifts into second gear
i agree that it's likely the valve body or the governor, but i'm just not sure which to check, would it be one of the valves that's not directly connected to the linkage? most of these i didn't touch when rebuilding the transmission so perhaps one got bumped or moved during the removal/installation
Old Nov 6, 2009 | 11:47 PM
sgt473's Avatar
Car: 87 Z28
Engine: LB9
Transmission: 4L60
Axle/Gears: 2:73
It sounds like your in to gears at once. If I remember correctly there were a few different valve body gaskets. uppers and lowers. The easiest thing to do is pull the valve body and go over the location of the gasket in reference to the spacer plate. Make sure that no holes are blocked and that the surface is flat and no miss aligned. If the fluid isn't burned you have a good chance of a repair.
Last edited by sgt473; Nov 6, 2009 at 11:48 PM. Reason: wasn't finished hit the wron key
Old Nov 6, 2009 | 11:50 PM
lucas1979's Avatar
i hope it's that easy
i used the smaller of the two gaskets i was given as i seem to remember the gasket being the same as the smaller one when i took it out, i didn't use any hi-tack to hold it in place, not even a dowel or bolt like i did with the pump, hindsight being 20/20 i probably should have
Old Nov 7, 2009 | 12:08 AM
sgt473's Avatar
Car: 87 Z28
Engine: LB9
Transmission: 4L60
Axle/Gears: 2:73
Do I understand that you only replaced 1 gasket. Never use hi-tack if you need to hold it in place use petroleum jelly.it's one of a few things that will not clog the filter. make some dowel pins from a longer 5/16 bolt to align the vb and spacer plate. make sure the governor screen is in the right place. and check all the valves for proper movement. don't use anything but compressed air to clean the vb. while you have the pan down check the clearance on the intermediate clutch pack, you will be able to see the clutches at the bottom of the case right behind the pump thru a round hole. you must have at least .060 use a drill bit to check for clearance.
Old Nov 7, 2009 | 12:12 AM
lucas1979's Avatar
there was only 1 gasket to replace i thought :S when i was reading through my th-350 book it said i would have 2 but would only need the one that fit....or so i thought
i should have .060 between the clutch pack and the pump right? will have to wait until i can afford another 8 quarts of ATF though
Old Nov 7, 2009 | 12:18 AM
sgt473's Avatar
Car: 87 Z28
Engine: LB9
Transmission: 4L60
Axle/Gears: 2:73
That's right. I've never had any luck with just using one gasket . Make sure you torque the valve body. they can warp and cause problems . If you take it down use a straight edge and make sure it's flat. Try a local trans shop they usually have the gaskets seperate so you don't have to buy a new kit. I'm sure you'll find the problem. good luck
Old Nov 7, 2009 | 12:20 AM
lucas1979's Avatar
yeah that would save me about 80$ on a kit
thanks for all your help sgt473, i will definitely post back when i get started and hopefully fix it
Old Feb 27, 2010 | 03:36 PM
lucas1979's Avatar
sorry it took so long to get a reply here, but i thought it would be best to update in case anyone else has the same issue.
I just got finished taking 1 steel and 1 friction plate out of the transmission and re-assembled it. I checked the clearance with an allen wrench i have and it's ~1/16th of an inch clearance now, that's with 2 steels, 2 frictions and the wave plate. Once my ring gear comes in this coming week i'll post the results of whether it all works out.
Thank you sgt473 for all your help so far
Old Feb 27, 2010 | 09:53 PM
sgt473's Avatar
Car: 87 Z28
Engine: LB9
Transmission: 4L60
Axle/Gears: 2:73
Hope everything works out. By the way how many cubic inches is your engine?
Old Feb 28, 2010 | 02:13 AM
lucas1979's Avatar
olds 403. Somebody put a ring gear from an olds 350 on it i just found out so i have been spending my week hunting down the proper one, now hopefully my starter will not grind or need any shims/washers to link up.
There aren't any other suprises i'm in for with clutch packs are there? the rest of them are standard 5 and 4 right?
Old Feb 28, 2010 | 09:08 PM
sgt473's Avatar
Car: 87 Z28
Engine: LB9
Transmission: 4L60
Axle/Gears: 2:73
I believe that the wrong intermediate clutch piston was installed in your trans.A majority of t350 built for the V6 and small V8's only had 2 intermediate clutches.An olds should have had 3 clutches. Try to find a complete pump or the proper piston. If you run the trans the way is is you may find it slips on hard throttle 1/2 shift. Hope this helps.
Old Feb 28, 2010 | 09:13 PM
lucas1979's Avatar
i would believe it, someone put the wrong ring gear on it as well along with the starter
when i drove it before it blew out the front seal, it would slip in drive when i was at a stop and accelerated, but other than that it was fine. I will know for sure what's going on when the gear somes on the second
where is the piston located and/or how can i tell if it's the right one?
i have another th-350 from a 66 impala sitting in my garage, would it be worth taking it apart and using the pump or would that be a bad idea?
Old Mar 1, 2010 | 10:23 AM
sgt473's Avatar
Car: 87 Z28
Engine: LB9
Transmission: 4L60
Axle/Gears: 2:73
The piston is the large aluminum one on the back of the front pump. Your Impala pump should have the proper piston but I wouldn't change the entire pump, just the piston. The proper piston will not be as tall as the one that only accepts 2 clutches. If I had one handy, I'd give you the specs.
Old Mar 7, 2010 | 04:05 PM
lucas1979's Avatar
well i did a test drive just now, and it's a lot better than before in that it will actually move in first when in Drive, but it still seems sluggish to all h***
i'm not sure where to look next, i know i need to replace the cooling lines as they are leaking like a filter, but that shouldn't cause this issue
the fluid is dang near dry on it though, not even registering on the dipstick (when warm) so i'm going to replace the cooler line that is causing the leak, then try again, will keep you updated and thanks again for all the help sgt473
Old Mar 8, 2010 | 04:52 PM
lucas1979's Avatar
ok so i did a lot of testing, and now here's what i know
Intermediate clutch pack has the right clearance and number of steels/friction plates
Vacuum Modulator has vacuum and is working
Oil level is optimal
Now when i put it in drive or manual low, if i press on the gas it will lunge forward as it should in low, then it will seemingly disengage or lockup and not move (if in direct low) or shift to secont (when in drive)
i hooked up the detent cable now and adjusted to no effect, i also tried with the modulator both hooked up and unhooked with no change. I really am at a loss with this whole thing now
anyone have any thoughts?
Old Mar 8, 2010 | 07:44 PM
sgt473's Avatar
Car: 87 Z28
Engine: LB9
Transmission: 4L60
Axle/Gears: 2:73
Does it go into second or does it slip? Is it full of fluid, should take at least 9 quarts depending in the size of the torque converter and pan size. How does it shift normal driving? Do you have a something to check trans line pressure? Is there a gasket behind the filter? I'm not fully understanding what's happening. Do you have 2nd 3rd and reverse and will it go into 3rd at all? Can you do a stall speed test?
Old Mar 8, 2010 | 08:16 PM
lucas1979's Avatar
in normal drive, i am sure it goes into second as i am able to keep the throttle pressed partway and accelerate forward, when in manual low, it will not move
it is full of fluid, the torque converter was full when i installed it and i have added ~8 quarts since then (it is rated as 10 when dry and some has spilt from the old cooling line)
when it's 2-3 in normal driving it is perfect, and it will engine brake normally
i don't have anything to check the line pressure
i believe there is a gasket behind the filter, but i can't be for sure without taking the pan off
i have reverse, 2nd and third. Reverse has full power without issue, i can chirp the tires in it
i can do a stall test tomorrow easily
2nd accelerates as it should after the car gets up to speed (20-25) and 3rd runs at ~1700 rpm @ 60mph
i'm beginning to think i may have something fubar in the valve body, maybe a wrong gasket or not torqued enough
Old Mar 8, 2010 | 11:41 PM
sgt473's Avatar
Car: 87 Z28
Engine: LB9
Transmission: 4L60
Axle/Gears: 2:73
I forgot to ask if you resealed the direct clutch drum, if so did you install the center lip seal and was the lip facing up. and how many check ***** did you install? Does the direct clutch accumulator have a plastic piston and did you check it for cracks. Are the bolts tight on the transfer plate and did you install the gasket correctly. That's all I can think of now good luck
Old Mar 26, 2010 | 03:02 AM
lucas1979's Avatar
well it's all done now.
after replacing the modulator, checking the governor and doing an entirely new teardown i found 2 problems.
1) finger tight plate bolts in the valve body assembly (the plate that goes towards the front of the assembly towards the pump
2) 1 too many steels in the low/reverse clutch pack
i had it with 6 steels, and 5 frictions in the order of steel steel, friction, steel, friction until 5 were installed
now it's got some fuel problems and might need a carb tune but that's expected with it sitting for ~1.5 years
also i put 3 steels and frictions in the intermediate clutch pack and bought a set of feeler guages to test and it was indeed needing 3 of them with ~.070 in of clearance
Old Mar 26, 2010 | 10:53 PM
sgt473's Avatar
Car: 87 Z28
Engine: LB9
Transmission: 4L60
Axle/Gears: 2:73
Glad to hear your on the road again.
Ghettobird52
Jul 5, 2024 11:18 PM
Vintageracer
Jan 10, 2020 05:33 PM
justin57
Aug 20, 2015 07:05 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
