700r4 shift at wot
Old Oct 18, 2009 | 10:55 PM
1993camarolt1's Avatar
700r4 shift at wot
I am having a porblem with my 700r4 or 4l60 tranny. Whatever it is. It is controlled by the tv cable like on all the 700r4's. My problem is that it does not want to shift out of first gear like it is hitting rev limiter and than it shifts. It will shift if im at 85% thottle just fine, but when its at wot it does not want to shift out of first. When i adjust the tv cable more loose it helps it not to hit rev limiter as bad, but than second gear shifts way to early at about 5,000 rpm's when it should shift at about 6000. Any ideas?
Any help is appreciated thanks
Old Oct 19, 2009 | 04:40 AM
Imthebriman's Avatar
Car: 1991 Camaro Z28
Engine: L98 5.7 350 TPI
Transmission: Brand New (again) 700r4
Axle/Gears: GM 10 bolt 7.625 W/ TrueTrac 3.23
Re: 700r4 shift at wot
it wont shift at WOT. From my experience all 700r4s are like that.
Old Oct 19, 2009 | 08:08 PM
What lol I hope they do lol. I figured it out. I need to get a governor recalibration kit because my first gear shifts to high and my second gear shifts to lowe\
Old Oct 20, 2009 | 10:40 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Then you don't have enough experience with functional 700s. I've never once had any of my 11-so-far 700R-4s fail to upshift out of first at WOT, whether stock or shift-kitted.
Old Oct 20, 2009 | 01:51 PM
Whoa! My bad. I think what I meant was they won't shift into OD at WOT. I'm sorry. I guess I should pay more attention to the Original Post next time. Thanks for pointing that out.
Pac J
May 17, 2020 10:44 AM
Damon
Sep 26, 2015 04:29 PM
indygene
Sep 26, 2015 11:21 AM
Dragonsys
Sep 25, 2015 03:51 PM
6998poncho
Sep 25, 2015 02:56 PM
