rear end noise when i let off the throttle?
Old Nov 1, 2009 | 09:38 PM
mike89firebird's Avatar
Car: 89 firebird
Transmission: 350 turbo
Axle/Gears: 3:42 gears
i changed my center chunk in my 89 to a 3:42 and now when i let off the throttle it makes a whirring sound. it dont do it when im in the throttle at all. maybe the pinion not tourqued enough?
Old Nov 1, 2009 | 11:03 PM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
Re: rear end noise when i let off the throttle?
What did you set the backlash to for the gears? Is there any back and forth play in the pinion?
Old Nov 2, 2009 | 06:47 AM
big gear head's Avatar
You probably didn't get the pinion depth set right. How did you set the pinion bearing preload?
Old Nov 5, 2009 | 05:26 PM
Car: 89 firebird
thanks for the reply! yea i didnt have the pinion tight enough. it had a bit of side to side play. all good now Thanks!
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
Jlanz55
Aug 17, 2015 07:15 AM
BlackBoulder
Aug 11, 2015 11:15 PM
novaderrik
Aug 10, 2015 12:44 PM
