Automatic transmission bushing removal
Old Nov 4, 2009 | 04:47 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Is it worth buying a "bushing cutting chisel" that uses the cut & curl method? Is it worth the $28 that bulkpart.com charges for it. My gut instinct is not to get it because it won't work as easily as I would expect it to.
Normally I just use the die grinder and cut a groove parallel with the bushing and then chisel it out.
Old Nov 4, 2009 | 05:53 PM
danandamy's Avatar
Car: 86 Camaro
Re: Automatic transmission bushing removal
Which bushing are you replacing? If it's the one in the tail shaft I always just yank off the tail shaft and drive it out.
Dan
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
What bushing?
JamesC
Old Nov 5, 2009 | 08:57 AM
junkcltr's Avatar
Engine: 3xx ci tubo
I am going to replace the entire set of bushings. I think it is worth just to do them all and start fresh for the rebuild.
jhawkeye
May 25, 2022 06:33 PM
Vintageracer
Jan 10, 2020 05:33 PM
Reddeath210
Oct 6, 2015 08:20 AM
milk
Aug 10, 2015 06:26 PM
3rdgenparts
Aug 8, 2015 07:09 PM
