T56 questions
Old Nov 12, 2009 | 01:57 AM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
T56 questions
I have a few questions about my t56 swap. I have an 85 camaro and was wondering how do I swap for a mechanical speed-o on it???? Also I am going to need a stock torque arm mount for it and was wondering if the t56 one is the same as a t5 or 700r4 mount??? Thanks
Old Nov 12, 2009 | 03:27 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Re: T56 questions
Mount is the same, i have no idea what to do about the mechanical problem. Think i am going to get a aftermarket speedo gauge and tach and mount them in the stock cluster.
Old Nov 12, 2009 | 03:52 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: T56 questions
http://www.skulte.com/T56.html
Speedometer Calibration
If you have a 90+ Camaro or an 87+ Firebird you already have an electronically driven speedometer. If not, the transmission's electronic signal has to get converted to a mechanical shaft drive, or the speedometer must be changed to an electrical unit. JTR (Jag's That Run) has a conversion kit available to change the electrical T56 output to a mechanical cable, but unfortunately, it is around $300. Abbot makes a black box that drives a cable speedometer as well, for a few hundred. Auto Meter has an electronically driven speedometer that accept's the VSS signal. I'm using this, along with a few others very succesfully.
Old Nov 12, 2009 | 06:47 AM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Re: T56 questions
Check with alloy here on TGO for a mech speed mod.
https://www.thirdgen.org/forums/tran...p-cheaper.html
Old Nov 12, 2009 | 01:33 PM
6SIX6's Avatar
Car: 89 IROC
Re: T56 questions
How does everyone run there speedo then. Im looking for options on how to hook it up as I'd like to start the swap soon and waht to have all the parts ready to go
Old Nov 12, 2009 | 01:48 PM
85MikeTPI's Avatar
Re: T56 questions
Did you read the link I posted?
You either get a converter box (Cable-X, Dakota), Run an aftermarket electronic speedo, or send off the tailhousing and have it modified to accept a mechanical VSS.
Old Nov 12, 2009 | 02:07 PM
6SIX6's Avatar
Car: 89 IROC
Re: T56 questions
So ALLOY is the guy who does them and how does it work, I just send mine off to him and he sends me another in return or he mods the one I got and sends it back.
Old Nov 14, 2009 | 11:17 PM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
Re: T56 questions
I mod your housing, I never swap them. Takes about 1 week turn around time. Shoot me a pm and we can discuss it in depth.
Old Nov 16, 2009 | 12:41 PM
6SIX6's Avatar
Car: 89 IROC
Re: T56 questions
Got your Pm alloy and i think i will be doing the Mod for sure. So what does everyone use for a crossmember and torque arm mount
Old Dec 3, 2009 | 07:40 AM
SydwayzTA's Avatar
Car: 1986 Trans Am
Re: T56 questions
Hey, I'm doing the same swap on my 1986 Trans Am, I have a T56 from a 95 Trans am. heres the best price i've found so far for a cross member to work with the T56 on your car.
http://www.hawksthirdgenparts.com/ca...93-97t-56.aspx
19irocz85
Aug 26, 2015 07:54 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
