Rear end noise
Old Dec 2, 2009 | 08:39 PM
1brd2brd3brd4's Avatar
Car: 93 Formula,88 T/A,01 WS6
Engine: 93 LT1,88TPI305,01 LS1
Transmission: 93 700R4,88 700R4,01 T56
Axle/Gears: 93 3:73's,88 3:42,01 3:40
Rear end noise
I put new gears in my car, now it whines on acceleration. I cant seem to find info on what to do to fix. I need to know which way to go. Pattern looked good when I checked it and backlash was in spec.never had this problem before and not sure what I need to do to fix it. Thanks for any info you could give me!
Old Dec 3, 2009 | 10:17 PM
Pew's Avatar
Pew
Car: 90 camaro
Engine: 355
Transmission: t10
Axle/Gears: 9" with 4.88's
Re: Rear end noise
most likely your pinion is in to far but with out being to see your pattern i cant really say for sure what did you set your backlash at?
Old Dec 4, 2009 | 06:55 AM
big gear head's Avatar
Re: Rear end noise
It's possible that you did everything right. Some gears will make a little noise no matter how you set them up. The 3.70 gears for the 9 bolt are a good example.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
BlackBoulder
Aug 11, 2015 11:15 PM
