700R4 and rubbing alcohol
Old Dec 11, 2009 | 05:33 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
has anyone ever heard of putting a bottle of rubbing alcohol into the tranny to relieve a stuck valve? If so, is it true?
Old Dec 11, 2009 | 09:19 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: 700R4 and rubbing alcohol
Yes cause it will just evaporates with heat; seafoam has a trans additive like that. Suppoe to clena then go away.
WARNING
After adding it my front trans seal leaked like a terrorist who took a .50 round in the chest.
The next day and after, it never leaked a drop again.
Scared the **** out of me though.
Old Dec 11, 2009 | 10:03 PM
WARNING
Funny that you said "leaked like a terrorist who took a .50 round in the chest. " I was is the US Army and I have seen what a .50 round does to flesh. Not pretty. Okay then. Im going to drop in a bottle to see if I can get my tranny to shift into OD. It also has trouble up shifting out of 1st. My IROC has been sitting for 7 years and its just been ressurected but with that slight tranny issue that I mentioned above. Thanks for the tip bro.
Old Dec 11, 2009 | 10:22 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
That kind of stuff sucks to see, I do mean it in jest. Never seen a 50 but a shotgun blast from about 8in away into a chest. & I figure about the same leakage wise in a funny way when you desensitize it with the word terrorist but in reality its god awful to see happen to anyone.
Does it manually shift fine on it own? Go up n down the gears on your own from a stop. If so that can mean its just sticky, how mine was, manually shifted just fine, and never slipped, but didn't want to shift on its own all the time.
Old Dec 11, 2009 | 11:04 PM
Nope. Im about to spray some WD-40 onto the "D" push button. See when I adjust the TV cable and open up the throttle, there is no click as in the "ratch sound" of the adjuster sliding out. Now as for shifting, when at a dead stop, I give it gas until the engine is at high revs, about 5,000 or more RPMs then itll shift into third after about 2 seconds of holding the pedal at high RPM's. It will not shift into OD. I tested out 2nd, no dice (stayed at high revs), so then I shift to 3rd, good, but when I shift to OD , nothing. So my uncle told me to pour a bottle of alcohol to see if itll looen up anything inside the tranny. Problem is that I already injected a bottle of Lucas tranny additive (boy is that stuff thick, like cold pancake syrup). The tranny is beginning to leak fluid from what I believe is the tranny. So is it wise to pour in the bottle even though there is that thick a** Lucas additive?
Old Dec 11, 2009 | 11:20 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Yea pour it in.
Hehehe I did all that too, same order, lucas, seafoam, then a trans fluid n filter change; it started to get better but I ended up getting a new trans built as I had just backed out of buying a car, well worth sending Discover $35 a month
A shift kit n higher stall TC makes me giggle sometimes as its just to much fun. I do now want a bit more stall and a smaller TC though.
[2200 12in now, 25-2800 10in plz]
Smaller the TC, the more torque mulitplication you get.
Just member they get hotter being smaller so a bigger trans cooler is needed.
Old Dec 12, 2009 | 12:04 AM
If this alcohol dont work, then Ill more likely to wait till income tax and just buy a rebuilt from http://sitekreator.com/Trans-Plant/main_page.html. Well thanks for the info Gumby. Peace
MrPackstin
Oct 25, 2017 08:09 PM
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
6998poncho
Sep 25, 2015 02:56 PM
