LT1 T56 to 1pc RMS block?
Old Dec 13, 2009 | 01:37 PM
IROC-You's Avatar
Car: 87 IROC-Z28
Engine: 414ci Twin Turbo
Axle/Gears: Ford 9"
If i had a donor 94 LT1/T56 camaro and an 87 auto 350tpi/700r4, what else would be required for the swap?
Would there be any special parts needed? Special clutch, special flywheel, etc?
I have been googling and searching Thirdgen.org for 3 hours now and just cannot find a simple answer. All i keep finding is crap about adapter plates, throwout bearings, special flywheels, etc. Its GOT to be easier then that!
Old Dec 13, 2009 | 02:07 PM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
Re: LT1 T56 to 1pc RMS block?
Since your motor is a 1 piece RMS you need the trans and shifter, bell housing, LT1 flywheel and clutch, and the master/slave cylinders from the T56 car. And a T56 swap crossmember.
Old Dec 13, 2009 | 06:41 PM
Drew's Avatar
http://www.skulte.com/T56.html
Old Dec 14, 2009 | 01:51 AM
IROC-You's Avatar
Car: 87 IROC-Z28
Axle/Gears: Ford 9"
Thank you for the quick and easy answer. Thats what I figured but I just wanted to make sure.
Old Dec 14, 2009 | 02:02 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
And pedals.
But yeah you can just use stock LT1 everything if you wish. It all bolts up no problem. The only thing you need to be aware of is that you need an LT1 specific flywheel. The LT1 T56's have a unique clutch setup. The good news is that the LT1 flywheels will bolt up to your motor no problem. But if you use a T5 flywheel it wont work.
Old Dec 14, 2009 | 10:22 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Try to use the 4th gen pedals if you can, i used the 3rd gens since mine was a T5 car and it is making noise when you put it too far down to the floor. But i dont have to press it down much to disengage it.
L0tuS
Oct 4, 2015 08:07 AM
New2Chevy
Sep 28, 2015 12:35 AM
88 TA GTA
LSX and LTX Parts
Sep 11, 2015 11:31 PM
L0tuS
Sep 4, 2015 11:16 PM
tonys91rs
Sep 2, 2015 07:07 PM
