Clutch suggestions please!
Old Dec 18, 2009 | 10:40 AM
robguitargod1's Avatar
Car: '91 LS6/T56/9"
Engine: LS6
Axle/Gears: Currie 9"/4.11, detroit truetrac
For an LT1 T56. I've been looking around, but haven't found anything people consistently suggest. Any thoughts? And please keep it under $1000! That's just sick. Probably 500hp MAX and occasionally track time. I'd just like something that I won't have to change every 3 months.
This guy here had a ton of problems:
http://www.bfranker.badz28.com/fbody/clutch.htm
Centerforce?
McLeod?
Ram?
Thanks guys.
Old Dec 18, 2009 | 12:18 PM
Car: '91 LS6/T56/9"
Engine: LS6
Re: Clutch suggestions please!
The guy from the link above suggested spec because it's what ultimately worked for him.
http://www.specclutch.com/cars/Chevy/Camaro/1997/Single
thoughts?
Old Dec 18, 2009 | 03:44 PM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
I use the Autozone LT4 Pressure Plate and a McLeod clutch disc. Saved a couple hundred $ and I got the idea here. The clutch grips well and the PP is lifetime warranty!
Old Dec 18, 2009 | 04:09 PM
Car: '91 LS6/T56/9"
Engine: LS6
Great idea! How's it hold up to moderate abuse and some track time? Thanks!
Old Dec 18, 2009 | 07:01 PM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Haven't been to the track yet, but I get on it like I'm at a drag strip every now and then, and it's held up to the abuse.
Old Dec 18, 2009 | 08:41 PM
Car: '91 LS6/T56/9"
Engine: LS6
So the wiki on GM LT4 engines says the LT4 was available in the 96 vette, 97 Camaro, and 97 firebird (firehawk). Yet the clutch for the vette is $100 more expensive than the camaro/firebird one even though they have the same trans right? Typical vette markup of the same ****?!
Robert
Old Dec 18, 2009 | 09:06 PM
Car: '91 LS6/T56/9"
Engine: LS6
Since autozone doesn't give you an LT1 and LT4 option I think the camaro/firebird PP is actually only for the LT1 cars.
Old Dec 18, 2009 | 11:02 PM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
bummer there isn't as big of a cluth selection for the LT1 crowd. You'd think they'd be a bit more popular since they're a more direct swap to older sbc's than an LS1 T-56.
Old Dec 18, 2009 | 11:30 PM
Car: '91 LS6/T56/9"
Engine: LS6
I think there's a pretty good selection, I just want to know which is ACTUALLY the LT4 pressure plate. I have suspicion it's the vette one not the camaro/firebird one.
Old Dec 19, 2009 | 08:05 AM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
The Autozone NU31265 clutch kit posted above has the LT4 PP. The differences between the LT1 and LT4 PP can be seen here. And I posted pics of the clutch kit here.
Old Dec 19, 2009 | 11:17 AM
Car: '91 LS6/T56/9"
Engine: LS6
Awesome, but I'm still curious what the difference is in the vette PP is. Also I found the McLeod disk for $172.89 shipped.
Old Dec 22, 2009 | 12:47 AM
Car: '91 LS6/T56/9"
Engine: LS6
The LT4 PP really is the same as any aftermarket PP!
$159 new not bad
devilschariot
Feb 25, 2016 03:08 AM
Drone358
Dec 10, 2015 08:16 PM
jtwoods4
Sep 3, 2015 05:39 PM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
