TV SLEEVE STUCK 700R4,HELP!!
My tv cable stuck the other day so i pulled the pan off today to investigate and everything seems fine(linkage,cable etc) except for the tv sleeve itself when i try to push the tv sleeve in manually with my finger it only goes in the valve body about half way and then stops like its hitting something in there,im no tranny expert so if anybody could point me in the right direction i would really really appreciate it!,thanks in advance.
Re: TV SLEEVE STUCK 700R4,HELP!!
When you pushed in the TV plunger with your finger, did it "stop" or just get harder to push in? Will the bell crank push it in further, if you push on the gas pedal? If there is a TransGo throttle valve installed (under the plunger), there will be more resistance when you push it in.
[CA] 700R4 trans & parts
6998poncho
Sep 25, 2015 02:56 PM
